Poslední návštěva: 23 led 2019 07:56 Právě je 23 led 2019 07:56
 [ Příspěvků: 5 ]
 Předmět příspěvku: Vyztužení karoserie pěnou
PříspěvekNapsal: 14 pro 2018 17:31
Řešil někdo vyztužení karoserie pěnou? Jako obdobu nebo dohromady se seam weldingem?
Citace:
Foam-Filling the Chassis
In any high-performance car, it is impossible to make the chassis too stiff. The stiffer the chassis, the higher its natural frequency, making the energy imparted to it by bumps less likely to excite the body's structure. A stiffer chassis enables the use of stiffer springs and shocks without hurting the ride. This is because a stiff, non-flexing chassis transfers more force into the suspension where it can be dissipated by the springs and shocks instead of transferring the force to the occupants. A stiff chassis is also more responsive to roll rate tuning for balancing understeer and oversteer. This is one of the reasons why automotive engineers are continually investigating ways to stiffen chassis without adding weight.
In a final bit of reengineering to stiffen the body, we injected the chassis with catalyzed rigid structural polyurethane foam. Structural foam, in the 2 lb per cubic foot density that we used, can stiffen chassis members up to 40 percent.
Higher densities of foam can increase stiffness by up to 300 percent. Since we cannot retool custom parts to redo the Z's body, we figured that this would be an excellent, low-cost way of greatly increasing chassis stiffness. Injecting foam is not a new technique for chassis stiffening. The Infiniti Q45 uses this sort of foam in some of its chassis members to increase stiffness, as do a few other premium cars. In fact, the foam we chose is the foam recommended to repair damaged Q45s.
To get the correct foam for our project, we contacted Art Goldman, Foamseal's automotive product manager and author of an SAE (Society of Automotive Engineers) paper on the use of structural foam for the stiffening of automotive unibody structures. We used Foamseal's two-component foam kit, p/n 11-22 to fill the main members of the chassis. Like we mentioned earlier, Foamseal is the supplier that I-CAR, a national certification group for quality auto repair, recommends for the repair of damaged, foam-filled chassis. The Foamseal kit uses a two-part catalyzed polyurethane foam, which quickly cures into rigid, waterproof, closed-cell foam. To prep the car, we carefully masked off all painted areas anywhere where the foam could drip. As this sort of foam is a thermosetting catalyzed plastic, we realized it could be icky if it spilled on paint or any part of the car's interior. This foam is nasty stuff. It is impervious to all known solvents and cleaners.
Rubber gloves must be worn. Get some of it on your hands and it will stay there for more than 3 weeks--don't ask how we know. Do not get this stuff on your paint. Wear old clothes; we ruined ours while learning how to handle the product. We injected the foam into the rocker panels and frame rails of Project Z through existing bolt and drain holes. When injected, the foam reacts like shaving cream and quickly expands to fill the empty space. You can judge how much foam to add by watching its expansion progress through some of the holes. Once injected, the foam expands and begins to cure in about a minute so you need to work fast and plan how you inject the foam before you start.
The life of the foam kit is limited to a few hours once the seal is broken. We filled all of the Z's unibody frame members using five foam kits. When foaming a chassis, you must remember the wires and other lines that pass through the chassis must be relocated or they will be entombed forever.
We were amazed at how this simple procedure improved the performance of the car. The chassis now almost feels like it has a roll cage. A sloped driveway can be driven up sideways with nary a creak. Even though the Z already has a pretty tight chassis, it feels more solid. The ride has improved and road noise has been reduced noticeably. We bet that the car will be even more responsive to chassis tuning measures in the future. If you are a slalom racer, a road racer, have a lowered car or even just want a smoother ride; foaming is a worthy, easy-to-do modification. Foamseal has foams in densities as high as 10 lbs per square foot if you desire to make things even stiffer.
Do not--I repeat--do not attempt to use cheap, hardware-store canned foam. This is not the same thing, and if injected into your chassis, will form a gummy mass that won't dry. Foamseal foam is a professional grade foam, which although it is a little unforgiving to cleanup mistakes, has superior mechanical properties and catalytic curing so it will dry even in an enclosed space.
Here is a to the foam:
http://www.foamseal.com/auto_aftermarket.htm
https://autofoam.net/autofoam/
https://forums.nicoclub.com/chassis-sti ... 70721.html
 Předmět příspěvku: Re: Vyztužení karoserie pěnou
PříspěvekNapsal: 14 pro 2018 18:33
Cpeme to do kastlí na autocross,ale i do nárazníků dveří atd. Super věc! 8)
PříspěvekNapsal: 14 pro 2018 19:05
Super, má to nějaké negetiva? Napadá mne jenom možný problém s rzi ale na druhou stranu by to nemělo absorbovat vodu a neměla by se tam ani kudy dostat a potom ještě problémy s případnýma opravama nosníků v případě nehody. Ale jinak jsem moc negativ nenašel. Použitelné by to teda mělo být i v civilním autě.
PříspěvekNapsal: 15 pro 2018 13:03
Závodnička bez problémů,ale do civilního auta bych to asi necpal. Ať říka výrobce co chce,každý PUR absorbuje vodu a drží ji v sobě.
PříspěvekNapsal: 16 pro 2018 14:51
V překvapivě hodně autech je to od výroby. Samo o sobě by to asi až tak nevadilo, ale ve spojení s ne úplně dotaženými spoji a nechtěnou blokací odtokových otvorů touto hmotou to samozřejmě svým způsobem korozi podporuje. Ale dle časového odstupu do roku výroby a poločasu rozpadu vozidla to dle mne až tak drastické nebude. Základ je to nervat do shnilé kastle a zamyslet se nad aplikací. Originál aplikace u promyšlenější konstrukce obsahují v oněch dutinách vložené přepážky, které tu hmotu zpacifikují kýženým směrem. Ono to auto většinou stejně shnije celé a i jinde, než je pěna.
www.vh-autoservis.cz
H S2000 AP1 / V 850 SW
 [ Příspěvků: 5 ]
